Lincoln race info?
Forum Description: Any other racing-related topics
URL: https://forum.bhpc.org.uk/forum_posts.asp?TID=41
Printed Date: 27 March 2026 at 4:44am
Topic: Lincoln race info?
Posted By: LeeW
Subject: Lincoln race info?
Date Posted: 21 March 2005 at 10:10am
Im was not sure where to put this so put it here.
When I click the link to see information about the Lincoln race, I get a 404, can you please fix?
Thank you.
Current fleet: Milan SL MK2 #027, Fujin SL II, Beany!
Posted By: gNick
Date Posted: 21 March 2005 at 12:11pm
It is down at the moment, probably because they haven't sent me a map despite being asked some time ago....
gNick
"I'm afraid it's definite, Mrs Banker - your son has bicycles"
Posted By: KevinJ
Date Posted: 21 March 2005 at 1:53pm
Not sure to why I think this is correct but try this
http://www.streetmap.co.uk/newmap.srf?x=497599&y=373399&z=1&sv=497599,373399&st=OSGrid&lu=N&tl=~&ar=y&bi=~&mapp=newmap.srf&searchp=newsearch.srf - http://www.streetmap.co.uk/newmap.srf?x=497599&y=373399& amp;z=1&sv=497599,373399&st=OSGrid&lu=N&tl=~ &ar=y&bi=~&mapp=newmap.srf&searchp=newsearch .srf
Kevin Jenkins
Windcheetah
Posted By: LeeW
Date Posted: 18 July 2005 at 8:16am
Have they sent you a map yet?
Date Posted: 18 July 2005 at 8:19am
Here are a few details from the web...
Yarborough Leisure Centre, Riseholme Road, Lincoln, LN1 3SP
Tel: 01522 873600.
Email: yarboroughlc@lincoln.gov.uk
Circuit - 1,500 metres
Width - 5 metres
Posted By: Adrian Setter
Date Posted: 18 July 2005 at 5:59pm
If you look here ( http://uk2.multimap.com/map/photo.cgi?client=public&X=497500&Y=373500&scale=10000&width=700&height=400&gride=497600&gridn=373404&lang=&db=pc&coordsys=gb - http://uk2.multimap.com/map/photo.cgi?client=public&X=49 7500&Y=373500&scale=10000&width=700&height=4 00&gride=497600&gridn=373404&lang=&db=pc& ;coordsys=gb )  you can easily pick out the leisure centre's running track.
At http://www.lincoln.gov.uk/Information_page_+_3_pic_det.asp?id=3382 - http://www.lincoln.gov.uk/Information_page_+_3_pic_det.asp?i d=3382  the cycle track is described thus: "The cycle track is a complete circuit of 1500 metres. The circuit comprises of two loops, the smaller equates to 833 metres".  From which I'm guessing that the cycle track is what you can see running around the perimeter of the site inna Preston Arena stylee.
Challenge Hurricane - MicWic Delta (Front half) - Burrows Ratracer
Posted By: Guests
Date Posted: 29 July 2005 at 11:47pm
When you say 'what you can see running around the perimiter of the site', Um, I can't see anything on this link that looks like a plan.
It sounds quite interesting. Maybe we could do a 'fun race' round the tighter circuit? I'm pleased to be offered the chance to see 'The Old Debtors Prison', but Lincoln used to have a pretty good cycle museum. I wonder if it's still there.
Jonathan
Posted By: Guests
Date Posted: 29 July 2005 at 11:55pm
Ooops - well at least it's not another international incedent this time. I realised which was the right link. I guess the track is roughly 2 halves. The North part looks like the tight circuit. Not sure if just that part can be ridden. Obviously there is no profile. Lincolnshire tends to be a bit like Norfolk - 'very flat'. However, the city itself has a some steep little hills. I was just thinking how good it would be to do the city crit circuit, but I think it's pave infested.
Jonathan
Posted By: LeeW
Date Posted: 30 July 2005 at 12:51am
Yes, the middle of Lincoln is full of cobbles and restricted zones, there is the famous "steep hill" which has a section about 1:3 which is cobbled but it is now pedestrian only.
Posted By: Yowie
Date Posted: 30 July 2005 at 1:11pm
Originally posted by LeeW LeeW wrote:
...the famous "steep hill" which has a section about 1:3 which is cobbled
There be Trike Territory only then
Posted By: Neil
Date Posted: 30 July 2005 at 5:35pm
Oh I don't know....
Posted By: LeeW
Date Posted: 07 August 2005 at 9:27pm
I went though lincoln a few days ago, I would not recommend going over the pavé in the center on a trike (or anykind of bike).  Pavé, High pressure tyres, stiff frames and Hardshell seats don't mix.  My hardshell seat had half the padding removed since I did a mock TT the day before and forgot to replace the padding, I seem faster with less padding (normally ride with 2" of padding) but it is harsher going over dreaded level crossings.  I did try riding up my local street once (chip-seal) with no padding atall, just sat on the fiberglass seat, never again.
Posted By: Neil
Date Posted: 07 August 2005 at 10:05pm
Out of interest, we have struggled in the past to find the right padding for darrens hardshell seat, bearing in mind he rides for up to 6 hours at a time and did over rode for over 14 hrs in a 24 hour period recently in swansea. Too much padding tends to loose power and cause too much sweating. We think at last we have found the solution in the form of a self adhesive neoprene type tape. This has so far lasted for over 30 hours of racing and still looks as good as new and appears to be the answer. Might be worth you giving it a try. You can just see it in this picture
Neil
Posted By: LeeW
Date Posted: 21 August 2005 at 6:34pm
Just wondering if they have sent that map yet.  I have looked at multimap and that air picture but cannot make out where the entrance and car-park are and from which road you access the circuit.
Posted By: gNick
Date Posted: 21 August 2005 at 8:58pm
Not yet - just back from holidays - will get directions asap though the webmeister is off for a bit so maps may have to be posted here...
gNick
Posted By: gNick
Date Posted: 22 August 2005 at 10:13am
I have just spoken to the track people and it is supposed to be easy to find.
The track is at Yarborough Leisure Centre, the entrance of which is well signed and on the West side of Riseholme Road which according to Multimap is also known as the B1226. I will post up a map from the Multimap website this evening (no picture editing software at work) and will see about getting something onto the website asap.
Power to the knees
gNick
Posted By: LeeW
Date Posted: 22 August 2005 at 5:16pm
My mum and dad might be going to newport with the car that weekend so I might have to ride the 35 miles to the race, and 35 back again!
Posted By: Neil
Date Posted: 23 August 2005 at 9:54am
Gnick asked me to upload these for him.
Neil
Date Posted: 23 August 2005 at 3:02pm
I notice that the immediate environs of the circuit feature a Laughton Way, a Chatterton Avenue and a number of Groves.  I wonder, is this an homage - though unfortunately misspelt in one case - to BHPC champions?
Posted By: gNick
Date Posted: 23 August 2005 at 3:19pm
Not sure about West of the track though - Dunkirk Road and Falklands, Tobruk and Anzio Closes...
gNick
Posted By: antony
Date Posted: 23 August 2005 at 4:03pm
And to the North-West, a nod to that famous 16th Century HPV racer, Queen Mary.
Posted By: gNick
Date Posted: 23 August 2005 at 4:30pm
And of course her arch rival Queen Elizabeth
gNick
Posted By: jes@gcre
Date Posted: 24 August 2005 at 5:11pm
Queen Elizabeth won by a short head!
Gettit?
Short head?
'Cos she ended up with one and Mary didn't?
I'm going.
Posted By: LeeW
Date Posted: 28 August 2005 at 5:46pm
Went to Lincoln today and checked out the circuit.  Finding it should be easy (last time I went to Lincoln, I thought we went down the road which went past the circuit but it was infact a diffrent road so no wonder I did not see anything which looked like a circuit.  The entrance to the leasure center is clearly signed and the circuit is accesses though the green gates between the leasure center and the school.
The surface is fairly smooth, there were a few patched up areas and a few cracks but nothing major.  The track did have quite a bit of overhanging vegetation but I was told that this would be removed prior to the race.  There was also a few twigs, stones, litter etc on the circuit but this should hopefully have been swept before the race.
When I went, part of the ciruit was a public path between the housing areas on either side and there were a few people walking dogs etc, I'm not sure if this path will be closed on race day and the gates at each end locked.  Maybe myself or someone else should contact the leisure center and find out?
There are toilets, changing rooms, showers and a cafe in the leisure center next to the circuit.  I'm not sure if there will be an extra charge to use the changing rooms, shall I find out?
Posted By: gNick
Date Posted: 28 August 2005 at 7:44pm
I have contacted the leisure centre - it appears that the locals are fairly amenable to cyclists so we don't (in fact can't) close of their access.
The issue on the day might be football matches on the pitches in the middle where players and their cars and occaisionally their balls will feel the need to cross the track. The players and cars have only one access point accross the track (they won't be trying to drive round the track like that donkey at Salt Ayre) but we will need a marshall or two. This mainly affects the outer circuit but I will make a decision as to whether we use the inner or outer tracks on the day.
gNick
Posted By: LeeW
Date Posted: 28 August 2005 at 9:03pm
I have made a rougth sketch with paint of the circuit.  I did not see a start/finish line anyware.  Do you know where the start/finish is?
Will there be any signs/marshals at the gates?  I can just imagine a dog or a kid stepping out infront of a streamliner doing 35Mph and the unpleasant consequences if there was a collision.
If the undergrouth is cut back, it will be easier to see around some of the tight corners in the north west part of the circuit where the undergrouth is currently quite thick and I could not really see around the corners at 72cm eye line.
Posted By: gNick
Date Posted: 29 August 2005 at 12:16pm
About the track I know nothing bar what those on the ground have told me - I don't think I have ever been to Lincoln.
My aim is to get there with plenty of time to get myself sorted and decide what we are going to do and where. We do still have some warning signs (I think), some marshalls vests and I definitely have some Hazard tape so we should be safe.
Lee - where are the football pitches in your scheme of things?
gNick
Posted By: LeeW
Date Posted: 29 August 2005 at 10:11pm
When I went, I saw some people playing football (I think they were anyway from what I saw) on where I have marked football pitches on the plan.  I did not get off my bike atall while on the circuit so could only see what could be seen from a 7" high seat.  I did not check the grass areas in the center to see if there were any pitches marked out, should have done really.  I think there is a seprate access to the north-west corner but not sure.
Posted By: LeeW
Date Posted: 31 August 2005 at 11:14pm
Here is a (rather badly drawn) map of lincoln
