New BHPC Forum
Category: Archive (pre-February 2015)
Forum Name: The BHPC
Forum Description: Discussion about the club
URL: https://forum.bhpc.org.uk/forum_posts.asp?TID=5079
Printed Date: 26 March 2026 at 11:55pm
Topic: New BHPC Forum
Subject: New BHPC Forum
Date Posted: 13 January 2015 at 9:45am
The Forum which you are currently visiting is soon to be replaced by an all new forum site. The new site is already up and running at the following address:
http://forum2.bhpc.org.uk" rel="nofollow - http://forum2.bhpc.org.uk
This address is only temporary: in about two weeks' time the old forum (this one) will be closed to new posts and renamed as 'forum1.bhpc.org.uk'. The existing address (forum.bhpc) will then be transferred to the new forum so that your bookmarks will continue to work.
You are very welcome to visit the new site, take a look, and perhaps post a comment or suggestion in the ' http://forum2.bhpc.org.uk/about-the-forum/" rel="nofollow - About the Forum ' section. Any problems or changes can then be sorted out in the next two weeks.
The whole of the new forum is open to anyone to read (except for a small private section for the BHPC committee) but you will need to http://forum2.bhpc.org.uk/login/" rel="nofollow - sign-in before you can post a message. You can sign-in with either a Facebook login, if you have one, or with a BHPC login. Please note that this means an account on the http://www.bhpc.org.uk/" rel="nofollow - BHPC website , not a login on the old forum. Usernames and passwords from the old forum will not work on the new forum.
Date Posted: 13 January 2015 at 1:24pm
Date Posted: 23 January 2015 at 4:59pm
The change to the new forum mentioned above will not now be going ahead. There will still be a new forum, but instead of being a separate entity the new forum will be integrated into the BHPC website. The address for the new forum is:
http://www.bhpc.org.uk/forums.aspx" rel="nofollow - http://www.bhpc.org.uk/forums.aspx
The 'Forum' button on the home page will point to the old forum until it is closed for new posts in a few days time so you will need the link above to see and try out the new forum.
As the new forum is part of the BHPC website you will need to login to the website before you can post to the forum. Fortunately the website will now accept Facebook, Twitter and Yahoo logins, as well as an existing website account, so logging in should now be much easier.
Date Posted: 25 January 2015 at 6:24pm
The old forum (the one you're reading now) will be closed for new posts on 1st February 2015. Various links and addresses will be changed so that the new forum takes over in its place from that date.
This forum will remain accessible as an archive via a link on the http://www.bhpc.org.uk/" rel="nofollow - BHPC homepage .
Date Posted: 01 February 2015 at 9:43am
This forum site is now closed for new posts.
The new forum is here:
or go to the http://www.bhpc.org.uk" rel="nofollow - BHPC website and click 'Forums' in the main menu.
