20 inch front forks
Forum Name: Wanted
Forum Description: You need something? Ask for it here
URL: https://forum.bhpc.org.uk/forum_posts.asp?TID=6861
Printed Date: 27 March 2026 at 1:18am
Topic: 20 inch front forks
Posted By: james1945
Subject: 20 inch front forks
Date Posted: 03 March 2019 at 12:03am
I need a set of 20 inch front forks 1 1/8 inch steering tube preferably designed for caliper brakes
Posted By: D.TEK
Date Posted: 03 March 2019 at 12:34pm
What is the min length of steerer tube ?
Oh and what brand and make of  two wheeler ?
Are you converting from 26" down to 20" by any chance
or just pranged the bike and need a replacement Confused
D.TEK HPVS purveyors of recumbent trikes and cycles
Date Posted: 05 March 2019 at 9:16am
I’m converting from 700 to 20””. The required minimum length of steerer tube is 200mm.
Date Posted: 05 March 2019 at 9:24am
Meant to add that the recumbent is a Performer Saki
Posted By: D.TEK
Date Posted: 05 March 2019 at 10:13am
I can offer a 20" carbon fibre fork suitable for side-pull brake system .
The alloy steerer tube is 245 (9 1/2 " ) approx. and 1 1/8 " dia .
Aheadset fixing not threaded .
Condition described as shop soiled test ridden a few times and removed and stored .
Pictures on request .
Over to you …..Kevin D
Date Posted: 05 March 2019 at 10:32am
Thanks for that. I need to recheck the existing steerer tube because there appears to be some confusion between the place I got the bike from and performer as to whether it’s straight or tapered. So need to take another look. So I’ll get back once I’ve done that. How much are you asking for the forks.
