It's best to read up about Solarfilm (the film covering) here: https://solarfilm.co.uk/collections/all" rel="nofollow - Products – Solarfilm Sales Ltd Solarfilm covering is a polypropylene, not as strong as a polyester film. It could slacken in a hot sun. It's also what I'd call a softer plastic whereas polyester is harder. Solarfilm (the company) does make polyester films too, as do other companies.
Remember, these coverings originally were made for model aircraft use. Bike wheel use is incidental.
Also, there are many more trade names such as Monokote in the USA, if it's still going. And, there's also a German variety, Oracover https://www.oracover.de/film/oracover/oracover-width_-60-cm-length_-2-m" rel="nofollow - ORACOVER iron-on film - width: 60 cm - length: 2 m - Oracover (expensive), very good for control line combat wings, (look that up): https://www.fai.org/page/f2-control-line" rel="nofollow - F2 - Control Line | World Air Sports Federation . My favourite covering that is not in model shops is Mylar, that's a trade name, strongest/lightest covering for F2D combat wings. Takes a good deal of heat and shrinks good too. Also, a cheap source of covering is/use to be Hobbyking: https://hobbyking.com/en_us/catalogsearch/result/?q=covering" rel="nofollow - Search results for: 'covering' A Hong Kong version of Oracover.
I'll let you look up Solartex (from Solarfilm), it's a fabric covering with a heat-sensitive glue. But, it can get ripped in use, I won't say easily but for combat wings we'd only use it occasionally. It was preferred to use ripstop nylon and dope instead, much stronger.
None of the iron-on coverings will stick to aluminium as it was designed to be use on wood, balsa in fact. It's soft so works best on that. You need to use a glue if you want to stick it on a bike wheel. Finding the right glue is paramount. Start with Evo stick or UHU, contact adhesive, but they keep changing the glue formulas. The old stuff is better. I've tried double-sided tapes but it's not reliable. The adhesive can soften in the sun.
Anyway, plastic film covering may last just the next time out or with careful use quite a few months. I've got some wheels that have had covering on for over a year (Mylar and Hobbyking stuff). But, they still have suffered hanger rash and needed patches on, to stay operational. Still ok to use and look good. Hope that helps. Martin
