  New Posts New Posts RSS Feed - What gearing for 20inch rear wheel
Andy TS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy TS Quote  Post ReplyReply Direct Link To This Post Topic: What gearing for 20inch rear wheel
    Posted: 24 August 2015 at 11:23am
Having put the 20inch rear wheel back on the Allewedder the gearing understandably is really low with the 52tooth chainring (87 - 30 gear inches) spinning out at 25mph
What gearing are people gerenally running with 20inch rear velos?
I have a monster 75tooth chainring which will give me quite a healthy range (125 - 43 gear inches) BUT a touch too high lowest gear for the hills and not sure it would be much use using the front derailier to shift off it...
may just stick it in anyway and just HTFU Angry
Allewedder A2, Broken Optima Baron Lowracer
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlanGoodman Quote  Post ReplyReply Direct Link To This Post Posted: 24 August 2015 at 11:44am
My little Catrike Speed has a Schlumph HSD which gives an effective 30/75 and works very well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy TS Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2015 at 12:06pm
got the big Chainring in but having a few alignment issues on the chainrun which are fiddly and frustrating but not insurmountable
